10 KW Max II PV problem
I have installed over 20 Units of the Voltronic Max II 10 kw inverters and found the last three inverters having a problem the PV side. I have 2 strings of 8 Jinko 580 panels going to the inverter and find at peak of the day the inverter trips for a second when the panels produces a-lot of power. There is no error of fault warning indicated on the inverter. It just cut out the output power and starts again. I have replaced a new unit on one of the installations and find the new unit works perfectly.
Has anyone had a similar or the same experience on the Voltronic max ii kw 10 inverter ?
