February 1, 20251 yr Can someone explain this for the Luxpower 5kw inverter TWO LOAD OUTPUT POWER: Full Load:3600W Maximum Main load:3600W Maximum Second load: 1200W Are there 2 output loads like 2 strings with 3600w and 1200w running separately? Just thinking how people have the db breakers wired and whether you get the full 5kw. Choice on inverter is Luxpower 5kw or growatt 5kw. Then thinking a 1C battery with Volta/hubble/greenrich. Any opinions or advice please from people using this system.
February 1, 20251 yr The max main load and max second load? where did you find it ? do you have a link?
