Earthing a solar system
Hi All
What would be the correct way to earth my solar system?
Earth rod into the ground then run a earth cable to DC combiner box and from there earth the inverter, battery and solar panels?
The AC coming from the main DB to the inverter do I use the earth from the main board into the AC inputs on the inverter or do I use the new earth rod?
Or do I combine both earthing systems together from the DC combiner?
Very confused when it comes to earthing my system please help and if you can keep it simple.
Carlo
Edited by Carlo7682
