April 8, 20251 yr Hi all.Is someone maybe able to assist here? I have a luxpower inverter connected to a sun battery. For the most part the coms seems to be working. The only issue I see is that the display of total AH of the battery is wrong. Does anyone have any info to remidy this and what is the ramifications of this being wrong. I am attaching a screenshot and battery manual SUN-CNY51280RN-51.2V-280Ah-14.34kWh-wheel-grouned-20241112.pdf
April 8, 20251 yr Have you used PBMS Tools to check what Ah values are reflected there?Hit the Read button when you are in this Tab to see what the BMS states.If the values here are as per the battery specs, then it could be a comms/protocol issue that the Inverter is not reflecting the correct infoCould well be that the max discharge current of 100A is reflected as 100Ah by the Inverter ? Edited April 8, 20251 yr by zsde
