Inverter error
Hi I am using a Stec Solarix inverter and had a fan problem. Code 01 appeared in the display and a beeping sound started. One of the two fans had stopped, so it was replaced. Both fans are now working, but the beeping and display of the 01 error code continue. Even after powering the system down overnight. As the problem has been fixed, what could the continued error message mean, and how can it be stopped?
