June 26, 20251 yr Hi can anyone helpWe are unable to add our inverter baxk to watchpower after it dissapeard. It says the wifi module is already added ? But no devices are showing up
June 26, 20251 yr You can try this - Delete the old configuration: If you're switching from a previous user or have changed WiFi password or networks, you might need to delete the existing WiFi configuration within the WatchPower app. Reset the WiFi module: Depending on your inverter model, there might be a reset button on the WiFi module itself, which can help resolve connection issues.
June 27, 20251 yr This should answer all your questions 🤞https://mppsolar.com/manual/Watchpower%20(off-grid)/WatchPower%20user%20manual.pdf
December 12, 2025Dec 12 Hi all, seperate issue, watchpower app recognises my inverter but says its offline. Ive deleted and reinstalled the app but nothing. Ive gone through the whole set up several times but it seems as if the inverter and router do not want to talk anymore. I am on v 1.7.1.0 for watchpower but cant seem to find any updates. Any thoughs?
