SETTING LIMIT POWER FOR LOGGER 100/3000 VIA MODBUS
Dear Guys.
I'm a Automation Engineer. I'm a newbie in Solar Areas.
Before I use Logger100/3000 to connect with solar inverter sungrow and run Zero export function on Logger.
The Limit power was set manually on configuring - webserver .
The Logger support Modbus, So can I change the Limit power setpoint via Modbus.
Many Thank.
