Inverter - Battery Combination advice
Hi All,
Please can you guys advise on what the better option would be:
8kw Deye Hybrid inverter paired with 2 x 5.1kwh Lithium battery 2nd Gen = 10year warranty on both inverter and batteries
8kw Deye Hybrid inverter paired with 2 x 5.5kwh Hubble lithium batteries AM2 = 5year warranty on both inverter and batteries
Effectively reducing warranty by going with Hubble battery despite larger capacity but price on both set ups is exactly the same
System will be used in conjunction with 12 x 575watt panels
Based in CT so was advised the Deye better vs Sunsynk in the event of failure repair and back up much quicker
Quoted around R120k for install and repair, seems reasonable compared to some other quotes
Any advice would be appreciated
Many thanks
