September 8, 20196 yr Greetings from India! After waiting a lot of years to get a better solar solution that's more evolved and reliable I am planning to go with the following Hybrid for my workplace, working hours are from 9 AM to 9 PM, Sundays Holiday. Infini V 5KW Longi 375Wp Mono PERC = 16 nos Exide 12v SolaTubular 150Ah = 8 nos Please suggest if any better options available. Also I would like to use some monitoring software. I find the ICC site inaccessible from India. I think i have to build something that uploads to PVOutput website using some ESP32/Raspberry/Laptop. Serial Command Set Information available? How is the reliability of the Infini V? Life? is the low voltage Solar DC input a disadvantage compared to the true Infini series? This doesn't seem to have a 4 stage/multi stage charger - so hows the battery life with this Inverter? Battery Equalizer required? I read here that the inverter consumes around ~125W to keeps itself running? if yes isn't that a loss on the energy generated? I think all inverters do not consume such high power. The fans are in reverse - against natural convection - is it recommended to switch the directions? Are there any other better options available? Actual Load is ~30KW. I need not run air con on battery power. Essential load is around 3KW, Total Load without Air Con is Max 5KW I hope the on-grid will help to reduce electricity bills due to the production on Sundays & offset when not using much load that compensates when running Air Conditioner.(22 ton AC) Or is the Axpert VM II 5KW with 5KW Solar Power is suitable for my usage, offgrid & buy more batteries? Power cuts are like 4-6 hours for 1-2 times per month Edited September 8, 20196 yr by kARTechnology
