July 20, 20206 yr Hi I have an option on these 2 inverters INFINISOLAR V2 5K-48V Or AXPERT VM3 5KVA Which one will be better. I want to run offgrid during the day, my usage is not much (0.7kw) except for the pool pump (1.1kw) and heat pump (1.2kw) but they both wont run at the same time. Will any of these 2 inverters be able combine PV with Utility to save on electricity? Thanks Axpert VM III_DS.pdf InfiniSolarV_II_DS.pdf
