February 14, 20215 yr Hi, I am looking for quotations on the following items. Alternatives can also be quoted on. SOLAR PANELS 1 JA Solar 535w Mono MBB Percium Half-Cell Silver Frame MC4 Qty 32 INVERTER 2 Huawei SUN2000 36KTL 36kW 3-Phase Grid Tie Inverter Qty 1 MONITORING SYSTEM 3 SMD DATA LOGGER MANAGER M (Up to 50 devices) Qty 1 4 Double Pair genuine RS483 cable 5M - 4 Core Qty 20 DC CABLING 5 SOLAR CABLE - 6mm BLACK Meter 100 6 SOLAR CABLE - 6mm RED Meter 100 7 W/MC4 CLIP (MALE/ FEMALE) Qty 5 8 MC4 PARALLEL KIT 3 SPLIT Qty 5 9 4mm BOOTLACE FERULLE (1PKT) Qty 5 10 1000V Fused Combiner Box 3 Inputs 1 Outputs 63A Isolator Type II SPD Meter 1 AC CABLING 11 FLAT TWIN-E CABLE 6MM Meter 50 12 FLAT TWIN-E CABLE 10MM Meter 50 13 10mm BOOTLACE FERULLE (1PKT) Qty 1 MOUNTING STRUCTURE - ALUMINIUM 14 P2000, 1.5MM X 6M ALUM. STRUT Qty 13 15 STAINLESS STEEL, SCREW ASSEMBLY + WASHERS Qty 100 16 FASTERNERS- CLIP MAGNI POWERSNAP Qty 128 BREAKERS & DB BOXES 17 32A DC DP BREAKER Qty 2 18 125A DC DP BREAKER / FUSE Qty 1 19 CIRCUIT BREAKER 3P 32 AMPS Qty 2 20 K&N Three Phase AC Switch Disconnector 63A Qty 1 21 12 WAY DB BOX DIN RAIL Qty 1 METERING 22 BI-Directional Metering Qty TRUNKING / CABLE MANAGEMENT 23 TRUNKING/CABLE TIES/HILTI NAILS / INSULATION TAPES ETC….. Qty 1
