October 3, 20214 yr Hi friends, newbie here and 1st post. I bought a Deye 8kw hybrid inverter and installed it next to existing 5 kw Zeversolar grid tied inverter. I will install an ATS auto switch to isolate the grid when their is a grid power failure. I will wire the grid tie inverter output to Deye inverter input and use the Deye grid to the grid terminal. Questions: will the Deye energize the grid thru its battery or solar panels or thru the grid tied inverter. I am in a compound here and the grid is spread out with pool pump and well pump in different locations so i want to re energize the grid after power failure and isolate the utility with the ATS.
