Slaaiblaar Posted October 6, 2021 Share Posted October 6, 2021 (edited) Did a clean install of HA and can not get my Victron equipment working on home assistant again. Anyone with experience please help. Edited October 6, 2021 by Slaaiblaar Quote Link to comment Share on other sites More sharing options...
Guest Sarel Posted October 6, 2021 Share Posted October 6, 2021 I had an issue with this a while back. Something unknown happened (it could have been me messing with it) and my Victron integration via modbus stopped. After a lot of searching and not finding anything on that online, I changed from calling the modbus.yaml and copied the parameters into the configuration.yaml file. That sorted my issue. I started by just doing the basics and one parameter after disabling the modbus call from within the configuration file. Hope this helps Quote Link to comment Share on other sites More sharing options...
Slaaiblaar Posted October 6, 2021 Author Share Posted October 6, 2021 6 hours ago, Sarel said: I had an issue with this a while back. Something unknown happened (it could have been me messing with it) and my Victron integration via modbus stopped. After a lot of searching and not finding anything on that online, I changed from calling the modbus.yaml and copied the parameters into the configuration.yaml file. That sorted my issue. I started by just doing the basics and one parameter after disabling the modbus call from within the configuration file. Hope this helps can you maybe send me a copy of your sensor configuration Quote Link to comment Share on other sites More sharing options...
Guest Sarel Posted October 6, 2021 Share Posted October 6, 2021 Sent you a PM. Quote Link to comment Share on other sites More sharing options...
Slaaiblaar Posted October 7, 2021 Author Share Posted October 7, 2021 13 hours ago, Sarel said: Sent you a PM. Thanks Quote Link to comment Share on other sites More sharing options...
