November 7, 20214 yr Hi all, I am going to be out of town for a few days. And you know, I have a feeling in my water that there will be some of that load shedding stuff going on. So is it possible to be able to control my Goodwe ES remotely? Currently I have to be attached to the same wifi network or to the Goodwe itself. I am guessing that I am going to need some device with a fixed IP address in the mix, but I'm no networking expert. Anyway to do this? So that if the weather is foul and ESP tell me that load shedding is about to start and I'm out of the house, I can use PV Master to switch into economy mode and charge my batteries?
November 11, 20214 yr Goodwe has two, three if you count historical, apps. One for local use only (EZManage rebranded to PV Master) and one for online access (SEMS Portal). Sign up on SEMS Portal and register your machine and you can access remotely and change some settings.
