November 11, 20214 yr Hi Everyone Like all of South Africa I'm trying to reduce loadshedding's impact by keeping a few things powered. My power needs aren't too crazy: 300 watt continuous draw, perhaps bursting to 500 watts for a few seconds. Total energy needed probably only around 600 watt-hours over 2.5 hours of loadshedding. I'm renting so can't cable into the DB, so the inverter/charger will need to have a plug/input for mains power to recharge the battery, and an outlet that I can attach a multi-plug to that devices will draw power from. Keen to use a lithium battery for improved cycle count and DoD. Which inverter/charger and battery combo will work best for this? I thought that a single Hubble S-100 100ah 12v battery would suffice along with a RTC 12v Axpert inverter/charger. Any advice would be much appreciated!
