December 1, 20214 yr Hi there. I would like to know when I sometimes use my kettle and the tumble dryer is on my plugs and earth leakage trips. I would like to know if the earth leakage trips will my lights and other things connected to the db board but not the plugs work. Example my stove is a separate switch on the db board so even if the plugs are down it will work. But if the earth leakage is down will it work? Please advice Thanks.
December 2, 20214 yr On 2021/12/01 at 10:53 PM, Aadz said: Hi there. I would like to know when I sometimes use my kettle and the tumble dryer is on my plugs and earth leakage trips. I would like to know if the earth leakage trips will my lights and other things connected to the db board but not the plugs work. Example my stove is a separate switch on the db board so even if the plugs are down it will work. But if the earth leakage is down will it work? Please advice Thanks. That would depend on how your DB is wired. Older installations only has the plugs on the Earth leakge. Modern installations has all the loads on the Earth leakge
