December 23, 20169 yr Hi all. We are picking up that some people have their single inverters set to master for parallel mode and then select the single inverter in AICC. This will create some issues as the protocol if different. Please make sure that your inverter is in single mode if you dont have a cluster set-up (You should not see the HS on the front panel). If you do have a cluster then set one as the master en select the cluster set-up in AICC. Dont run your single as a cluster and choose cluster on AICC also. Make sure your mode is correct.
