Posted January 8, 20223 yr Over time I have upgraded my solar input and battery bank and have added an 7.2kw EVSE to my setup. This has made my Multiplus 1 5kw 48V sortof redundant, as it is too small to cope with the load. I have two options as far as I can see. If I add one more multiplus to the mix, it may be just too small to cope with the load, supplying the balance from the grid or replacing the inverter with a quattro 15kw, which will have room to spare. Are there any pitfalls I need to watch out for when making the switch or is there a reason to rather add one or two more multiplus 1's to the mix?
