February 2, 20224 yr Hi. I had an installer setup a Growatt 5KW with a Hubble 5.5KW battery. Since installation, I’ve had three blown coils - (2 on the garage door motor and 1 in the sliding gate motor. Both motors are ET. I’ve now had to remove this circuit from the solar backup supply. The Frequency on the inverter is set to 50Hz - which I thought could be causing the problem. Any ideas what is causing this? Edited February 2, 20224 yr by Bashir
