January 12, 20179 yr This seems to have been removed from the AICC website. Have just managed to set up my Raspberry Pi (bought for AICC) but now cannot download the software. Please let me know where the .rar is available. Thanks.
January 12, 20179 yr Author 4 minutes ago, cvzyl said: http://iccsoftware.co.za/ Thanks - new website. What's the difference between the 3 downloads? Not sure which I need. I will be installing this on Raspbian on a Pi 3 B. I installed Raspbian Lite and then added the "lite" version of Pixel GUI.
January 12, 20179 yr I think you need ICC Pi. It contains only the ICC program. The Pi Image is a complete OS plus the software preconfigured. As you already have the Pi with OS up and running you only need the ICC program.
January 12, 20179 yr Author 2 minutes ago, cvzyl said: I think you need ICC Pi. It contains only the ICC program. The Pi Image is a complete OS plus the software preconfigured. As you already have the Pi with OS up and running you only need the ICC program. OK, thanks, that makes sense. If I had know there was a preconfigured version I would have used that - great idea. Just out of interest, what is the MQQT version?
January 12, 20179 yr It is a Windows based app that you can run as a remote display, either on your local network or via the internet. You can see the trends and data from the inverter live.
January 12, 20179 yr Author 2 minutes ago, cvzyl said: It is a Windows based app that you can run as a remote display, either on your local network or via the internet. You can see the trends and data from the inverter live. Ah, yes, I remember seeing discussions about that. So that is separate from any VNC RD you may set up to control the software and inverters remotely? Perhaps just a view only app for data views? I see the new site is under development so nothing yet in the "Help" area. I think there is an install.txt file in the zip so I'll see if I can manage to get it all set up with that. If I have problems I'll come back here for advice. Thanks for the info.
January 12, 20179 yr Yes, I think Manie recently setup the new site, it will develop over time. The easiest way to get everything running is probably with the image file. Yes, the MQQT app allows for remote view only, no control.
March 13, 20206 yr On 2019/05/10 at 2:28 AM, Salman Kazi said: I want to monitor my axpert 5kw VMII inverter. I have raspberry pi 3 . What next ? exactly, I have the same inverter links to the page with this program are out of date
