February 26, 20224 yr I have a couple of questions. 1) Under settings - Schedule - Battery SOC Control - could someone please explain to me how this works, I am trying to get my battery to start charging at 85% SOC and stay switched onto SUB/SOL all the time. Please assist me to get this right. 2) I continuously have a low very low battery warning when my battery drops below 95% SOC what setting must I change to get this right? 3) Why can I only see the voltage and amperage of the first string of solar panels linked to PV 1 sockets on SMH? This happens on both my Inverter information shown on SMH. 4) When I measure my solar voltage input the highest voltage I get is 370 volts, why does my SMH software show the voltage as 470 Volts on the main display screen? 5) Is there a patch for the SMH software to read the cycle and battery ID details from Pylontech US3000B batteries running with US3000C batteries?
March 6, 20224 yr Author On 2022/02/26 at 5:42 PM, Venom said: I have a couple of questions. 1) Under settings - Schedule - Battery SOC Control - could someone please explain to me how this works, I am trying to get my battery to start charging at 85% SOC and stay switched onto SUB/SOL all the time. Please assist me to get this right. 2) I continuously have a low very low battery warning when my battery drops below 95% SOC what setting must I change to get this right? 3) Why can I only see the voltage and amperage of the first string of solar panels linked to PV 1 sockets on SMH? This happens on both my Inverter information shown on SMH. 4) When I measure my solar voltage input the highest voltage I get is 370 volts, why does my SMH software show the voltage as 470 Volts on the main display screen? 5) Is there a patch for the SMH software to read the cycle and battery ID details from Pylontech US3000B batteries running with US3000C batteries? Anyone?
May 31, 20233 yr I assume by now you have this running smoothly What is the costs involved for subscription And for the initial setup, i assume you have the be logged in, what is the defaults ?
