March 16, 20224 yr Good morning all I need some help. I dont know all the in's and out's of the solar setup. I want to best utilise my solar, to minimise my utility bill. I currently have 12 330W poly panels, 2x 4.8 kwa Narada 48NPFC100 batteries, and a 5kwa RCT inverter. Currently the settings are set to SUB (Solar first, then utility and then battery). This causes the utility to kick in around 18h30 in the summer My batteries are fully charged, and technically not being used at the moment. Most of the other settings are set to default Here is the current problem: Before, I had the setting to SBU (Solar, Battery, then utility) However, often it happened that the 1 battery was dead (depleted) by the morning. This happened due to the battery being used from mid afternoon some days (around 14h00 or 15h00) How do I ensure the following: 1) Solar should be used when available for all household requirements 2) Batteries should charge during the day to max capacity, using solar 3) Batteries should be used when solar not available, but should not be depleted. if battery capacity drops below 25%, utility power should be used 4) Solar should then charge batteries again once available I have checked, and 90% of the time, my usage is at 18-25% of capacity If I need to be more specific or add more detail, I am happy to. I just need some guidance in terms of using all the voltage and utility, etc settings Thank you Stef
March 18, 20224 yr Hi Stef. It seems that the comms between the 2 batteries aren't working. You said that one battery is almost depleted. They should work together and depleted as one. Regarding your other concern look at getting a Raspberry Pi with Solar assistant or something the same to utilize your system to its max.
