Growatt Shine app code
49 minutes ago, AhmedDoc said:
Hi, could anyone assist with the installer code so I may register on the shine app
Try this one. Not sure if it still works. BMYR8
  • 10 months later...
For anyone finding this in future, it is a bad idea to use any old installer code. This will add your datalogger to that installer's account.
Unless you don't mind a random person knowing about your installation, I would not do this.
If you want your own installer code use this site to register for a code: https://oss.growatt.com/login?lang=en
  • 3 months later...
  • 11 months later...
The installer code is required for most countries.. but if you select United States then you will be able to leave the code blank.. this may also work with other countries but not tested.. doesn't work for UK.
  • 4 months later...
