March 15, 20224 yr Hi, could anyone assist with the installer code so I may register on the shine app
March 15, 20224 yr 49 minutes ago, AhmedDoc said: Hi, could anyone assist with the installer code so I may register on the shine app Try this one. Not sure if it still works. BMYR8
March 17, 20224 yr Author On 2022/03/15 at 11:53 PM, zsde said: Try this one. Not sure if it still works. BMYR8 It worked. Thank you!
January 27, 20233 yr For anyone finding this in future, it is a bad idea to use any old installer code. This will add your datalogger to that installer's account. Unless you don't mind a random person knowing about your installation, I would not do this. If you want your own installer code use this site to register for a code: https://oss.growatt.com/login?lang=en
May 17, 20233 yr On 2022/03/15 at 11:53 PM, zsde said: Try this one. Not sure if it still works. BMYR8 still works thanks alot man
April 28, 20242 yr The installer code is required for most countries.. but if you select United States then you will be able to leave the code blank.. this may also work with other countries but not tested.. doesn't work for UK.
