Growatt inverter not holding float voltage
Hi I have installed a 5000 Watt Growatt inverter , all is running well apart from the float voltage . I have attached a video the float voltage is reached then it seems the inverter takes power from the battery and then needs to charge again to get to float voltage. I am running deep cycle battery's so not sure if the is normal behavior  .
  • 1 year later...
