March 23, 20224 yr Good day, I have a client with a GROWATT SPF5000ES inverter and a 5.8kWh SOLARWISE battery, but the communication is not as what it should be. What protocol on the lithium setting must be used? I tried from 01 -09 and also 52, it keeps giving a comms error. The patch cable is correct. Any ideas.
February 11, 20233 yr Hey, i wanted to check if you ever got a answer to this problem as i need to deal with the same thing and can you advise on the cables and other things as solarwise is useless with answering anything. thank you
