May 5, 20224 yr Hi. So I just noticed the attached error on my prepaid meter. Is this normal, as it's not configured to export to grid?
May 5, 20224 yr I have the same prepaid meter. I get that error all the time IF I leave it turned on & plugged into a backed up circuit. The problem is on the CIU, not the actual meter. My system is set to not export.
