June 24, 20224 yr Good Morning Please can someone assist me. I have a Growat SPF5000ES Inverter and a Hoselect 4.8KW wall mounted battery. On the Hoeselct pdf it says it can communicate to SPF5000es but i am not having any sucsess. I have tried all the port options. Can someone help me please. Edited June 25, 20224 yr by Manie
July 14, 20223 yr Hi, i am struggling with the same issue, have you managed to find a resolution yet? From the research i have done, i can see that it would probably be best to connect via the CAN connection, but it will require a crossover cable as the pins are opposite. the protocol is still the grey area for me, i know it has to be one that from 50-99
