ICC Software problem
Hi Yáll
I hope you are all well.
I have 3x Axpert King inverters and 4x Kodak BL3.6 batteries working with a Raspberry Pi4 with ICC software loaded
I am having a weird problem on my Pi4 with ICC software loaded. For some reason there are massive fluctuations on my display. One of the most notable is that every now and again the Battery Volts dial goes from say 56V to 45V for 1-2 seconds and then goes back to the true battery reading. This is playing havoc with the graph below on the screen and also with the history.
I have asked ICC and they said it is most likely the Victron BMW. I am a little hesitant to believe that the Worlds best solar component manufacturer is at fault. It might be a coincidence, but this problem started after activating the ICC GPIO software on my Pi4 and having them set it up to work with the ICC monitoring software.
I am also struggling to get the ICC software to read the Kodak BL3.6 batteries data and to display the batteries true state of charge ext. Can someone help me please?
Are the Kodak batteries not just re-branded Pylontech's?
