October 8, 20223 yr Hi everyone, I'm new to the forum and wanted to ask if anyone had this problem and how they solved it: I have a Goodwe GW5048-ESA inverter with a 5.4 kWh Goodwe battery, in the summer when the cooling fan starts, it no longer stops even at low temperatures, the only way to stop it is to disconnect the fan connector, in this way it resets itself and until it reaches the start temperature again they do not start. I asked my installer, but he told me that it is normal in the summer, now anyway I will try to insist, but in my opinion the sensor could have some problem. thank you all
