Afore ATON Hybrid AF 6K-SL - Battery settings clarification needed
I have so far been dealing DYI only with Voltronic/PIP/Axpert type inverters.
Recently we have purchased and installed this one. It looks good quality and works well and is very silent below 3kw of PV power.
There are however some settings which do not work as expected.
For example I have set up Maximum charging and Discharging currents to not exceed 20amps  and max chg Pwr 1020W- but it does not work as expected.......it first charges with as much as it gets up to 46-50amps until the SOC% increase above 50-70-% and then restricts to 20amps..... but I would like to have that restrition all the way
Have anyone played with these/similar models before ? Do you know , if Afore is similar to any other brand as I do not find any information about this name in the forums ?
Thanks !
Parameters extract and screenshot info:
- EMS Param Chg Pwr – 1020Watts
-EMS Param Chg Range
               *SOC Max 80%
               *SOC Min 20%
               *VbatMax 54V
               *VbatMin 51V
               *IchgMax 20A
               *IDchgMax 20A
Single Phase Hybrid Inverter1-6kW - Afore New Energy (aforenergy.com)
  • 10 months later...
