October 17, 20223 yr Hi Hi All I am considering the above models @ the 540w range, are any of the above recommended above the other? I general pricing Canadian is slightly more expensive then JA then Jinko. Edited October 17, 20223 yr by uDuWaR spelling
October 17, 20223 yr The normal consumer would be hard pressed to realise a difference. It will be an opinion unless you install all three on independent systems and do your own comparison. May end up with a 1% difference in performance? Do some searching on comparisons on the net and decide which one you feel comfortable with. Here is one such overview with Jinko and Canadian. There are many others. https://lightningsolar.com.au/canadian-vs-jinko-solar-panels/
October 17, 20223 yr Author Thank ZSDE Yeah, pretty much can't go wrong with any of those. I was just checking if there was any reason not to go with any of them. Regards, Dudley
