October 18, 20223 yr Good morning I recently bought a new Pylontech battery (US3000c) and made it the master of two US3000 batteries I wanted to connect the BMS to the inverter and used a number of iterations with respect to a RS485 comms cable and nothing worked. I came across a document from Segen Solar stating that there is a firmware issue. If one has firmware U2 112.14, then the communication will not work Has anyone with the above firmware revision managed to get the communcaiton between a Kodak 7.2OG inverter working with a US3000c battery? Thanks Kodak-inverter-user-settings-guide-1.1.pdf Edited October 18, 20223 yr by Kenneth99 Forgot to include attachment
