Inverter Lithium battery communications settings protocal?
I have a SACOLAR - WIFI COMPATIBLE- 5KVA / 5KW PURE SINE WAVE AXPERT TYPE INVERTER / 80A LOW VOLTAGE MPPT / PARALLEL and a Shoto SDC 10 Box 5 (5.12kWh) lithium battery, inverter BMS port connected to battery CAN port, Can anyone help with settings, on inverter 05 battery is Li, then 36 protocal is Lo52, is this correct or anyone send me correct settings?
