Sunsynk 2 x 8KW restrict export KW
When Battery is fully charged, Setting Inverter power limiter to 1500 w (3KW 2 Inverters) it still trys to
push what ever the PV can produce anything from 9-19KW and Grid voltage goes high and shuts it off,
and I get a notification.  It keeps trying until I set it back to zero export.
Why it does not just slowly increase the current up to set limit.
If the PV is producing no more than about 4KW above house load it seems to work, I think the problem is because it puts + 9 out and
there is not time for it to read CT and adjust before the High Voltage.
Any Idea's to solve it.
