November 29, 20223 yr I have a raspb pi that i cant connect to. Its getting power but no response, even tried re-flashing the sd card with new files from solar assistant using recommended program for doing so. But nothing no wifi, bluetooth and no ethernet connection any advice.
November 30, 20223 yr Which model RPI do you have? Try a different SD card - I had a card that would seem to flash, but refused to work. Can you see the partitions on a PC? Try flashing regular Raspberry Pi OS (Debian 11) and then connect the RPI to a USB keyboard & HDMI screen and boot.
