Luxpower SNA5000 system working mode code and other...
Hi, I'm Cris,
          installed some days ago an Luxpower inverter and meritsun 48V 100Ah battery.
I can't understand very well how the inverter is working. In my home automation, I can read realtime power consumption from grid. I added a second sensor for inverter output measurement power. Now the inverter is working in UPS/EPS mode(hybrid disabled).
Invert has 60W power consumption (about 3W in sleep mode), this "function power" is provided by battery (if charge) or by grid.
On display I can see various working modes codes: now is "C0", sometimes I can see "00", yesterday it was "14". Is there a datasheet about these codes?
Other, tow days ago, I enabled the hybrid mode. Inverter use the grid power during the power variation and this is ok for me, but in the evening, with a battery 50% SOC, inverter absorbe 60W from grid and not from battery, why? Example: my home consumption 100W, checking on my home automation power meter I see 160W. In hybrid mode inverter takes power from battery only during the PV panels production?
At the end, for now there is no communication between inverter and Meritsun battery. Using RS485 port and provided cable and battery code 11 but no communication. Now I'm working with a configuration for lead battery but Ithink I need to optimize parameters... I'm waiting for a support.
Dongle and Wifi configuration was very simple.
