So I have 2 setups
1: Synapse 7.2M+ (Axpert Max) with 2 x CFE 5100s batteries
2. Kodak 10KW (Axpert Max II) with 2 x CFE 5100s batteries
So has anyone managed to get the BMS communication with these inverters ?
I had CFE Tech update the firmware on (1.) - after which the inverter does connect to the battery BMS - but seems to lose connection at some point (Warning 60) and other erratic errors - when setting manual parameters and removing the bms cable - no errors or warnings - and everything works
I have not had them update the second pair's firmware as I see no point at this stage so running manual settings atm.
Anybody has any advice ?
I'll keep at it with the Guys from CFE from my side...
I have a stable system in the wild using the LuxPower with the CFE (2 Months now). I also want to use 2x CFE with a Kodak 7.2 Max (Axpert Max) and see what I can find.
Do you know what firmware the Synapse 7.2M+ (Axpert Max) is running?
45.07 and panel firmware 12.13 - also see my DM reply
Edited by Rosh
Has anyone had success yet?
I am looking to connect a CFE5100s to my axpert king mk ii. There's little to no information on how (Using the BMS) though.
I know a firmware update or change may be needed but not sure who to contact for this.
23 hours ago, Fabs said:
Contact Owen - 27 84 975 5067 from CNBM - he can put you in touch with the Tech people - Setting the batteries to communicate with the inverter is pretty simple though the dip switches as referred to in the manual - the problem is the erractic behaviour thereafter - even after several attempts at modifying the firmware by CFE Technicians
