December 23, 20223 yr Calling on anyone that has done a panel installation on Harvey Tiles (Metal Tiles) Are there any special mounting brackets in the market or did you devise a clever method of securing a bracket outside of drilling holes through from the top.
December 23, 20223 yr 58 minutes ago, zsde said: Calling on anyone that has done a panel installation on Harvey Tiles (Metal Tiles) Are there any special mounting brackets in the market or did you devise a clever method of securing a bracket outside of drilling holes through from the top. I have done my own own roof with special brackets from MacSteel. I bought them directly from factory in Benoni. Galvanised steel, specially made to screw on the brandering, because of that you need to place more of them per length. Non intrusive, no holes or bends of tiles required. (Macsteel is owner of Harvey)
December 23, 20223 yr Author 13 minutes ago, BritishRacingGreen said: special brackets from MacSteel Thanks mate. Appreciated. Do you have a pic of how you attached them? Edited December 23, 20223 yr by zsde
December 23, 20223 yr 3 minutes ago, zsde said: Thanks mate. Appreciated. Do you have a pic of how you attached them? Give me a moment to jump on the roof and see if one of them is exposed for an image.
December 23, 20223 yr Just now, BritishRacingGreen said: The portion you cannot see is the part that clips and screws onto the underlying brandering.
December 23, 20223 yr Author Thank you. So a row or two of the Tiles have to be lifted before attaching these brackets it seems.
