January 10, 20233 yr Hi Guys If I understand correctly, I can use my electrical oven even though I am totally off grid, providing my maximum power consumption does not exceed my inverter size. Correct? I have a 5Kw inverter my maximum consumption for the oven is 2.4Kw Regards Limpopoboy
January 10, 20233 yr No problem as long as you stay inside the Inverter output rating. I use it for my 3kW Geyser element as well. It's a matter of managing your consumption with the available energy.
January 10, 20233 yr Yes you can use your oven on the 5kw inverter. Some management to do to ensure that no other large loads are switched on. Your battery must also be able to handle the load over a long period even if using the oven during the day. It takes 1 cloud to drop your pv production.
