Posted January 13, 20232 yr Hi , we have an axpert 5KVA which runs at 8percent or load approx 400Watts and 8amp (can bring down to around 350watt and 6amp by unplugging the fridge. The axpert doesn't accept a cutoff of under 50 percent so we can't really use the advantage of lithum to go to Discharge of 30 percent. Which lithium battery to get that we can monitor (ideally via cloud or app) that will last a 4 hour load shedding. Don't need solar Happy to get a different Inverter too. Thank you so much. Shaun
