January 13, 20233 yr Hi, seems like my sunsynk 3.8kw inverted is pulling power from the grid to charge my battery that I do not want to do. Yes any solar to house and battery then excess to the grid but I have found that with the timer on, grid not checked zero export, % in all areas at 20%, battery grid charge off the system still charges from 20 - 24% like it is pulse charging- what can I do to stop the pulse charging - this has only started a day ago and Just need to know what I can do - any advice - attached in reverse order is there screenshots, one showing the system working IMO normal ash with solar charging battery, second part solar charge the pulse charging with third just pulse charging - bit of a loss here?? would appreciate help to a newbie JP Edited January 13, 20233 yr by Jaytea Update
