Luxpower sna 5000 weird voltages
Good morning all
Need some technical assistance
Luxpower 5kw inverter with dyness 5kw battery
All installed professionally with coc
I'm getting weird voltages when inverter is running from battery no grid
Line to neutral 225v
Line to earth 261v
Neutral to earth 40v
Can anyone help I have installed 3 of the same systems and only have this issue on one
The place I purchased from is of no help whatsoever they suggest I join a whatsapp group
Attached is some pics
28 minutes ago, Sakkie Swart said:
Hi, your installer did not install a Neutral Earth bonding relay
afaik the sna5000 does not need the relay as it has it's own internal bonding. Perhaps there is a setting that enables or disables it?
  • 5 months later...
I have noticed that via the installers login there is this option:
When I enquired with Luxpower local SA support via Whatsapp they said that I only need to set it to enabled if I do not have panels.
That does not make sense to me, although without a battery I cannot run my inverter in islanding mode so have not been able to do much in terms of testing.
@Mr 350 Has your issue been resolved? I assume you are not sure what was done / changed to resolve the issue?
