Panel Amp output
Hi guys once ive accounted for weather and the fluctuations in volts. How does the amp output per panel affect the sunsynk 5kw inverter because it says max is 11 + 11 and also is theat per string? Thank you.
It is per MPPT of which there are 2. Thus your series string that goes to each MPPT.
