Deye Inverter and Dyness PowerBox
Hi All,
I have 2 installations at 2 different personal residences. Both are backup systems with no solar.
Setup 1 has a 5kw Deye Inverter with a 5kw Freedom Won battery. I want to ask is it normal that the Deye home screen shows the grid and battery powering the home?
The graph shows the grid putting 0.23kw to the home along with the battery, at 99% SOC, is putting 0.02kw, with the house using 0.25kw. I thought the battery would charge to 100% and then just be on standby until the grid goes down? Or should the battery be constantly feeding it the house in these small increments,even when the grid is powering the house?
Setup 2 query is a 5kw Deye inverter also, but with a 10kw Dyness Powebox.
The issue here is that the battery only charges to 80% so there is some setting that is incorrect that is not allowing the battery to fully charge. DoD should be at 20% but I need to confirm this setting also.
Also, both are only showing "AC" and "Normal" - others I've seen show DC also green?
Pleaser help with confirming if setup 1 is correct and then the setting that I need to update for setup 2.
Thanks, Eust
The DC LED illuminates when solar PV is producing.
