March 7, 20233 yr good day i have a deye inverter giving me trouble as soon as it hits loadshedding the unit switches on and off by itself i am useing five star 7,2kw hour lithuim battery's its only with loadshedding what can be the cause please assist
March 7, 20233 yr Incorrect installation on AC side, ring feed from output to input, hot connection on battery, incorrect setting on inverter, comms issue to battery, factory reset required, faulty equipment... many options. The Deye inverters are reasonably solid to my knowledge but you would have to do some fault finding to identify the cause.
