March 13, 20233 yr Hi everyone. I am new to solar and finding new things every day. I have an off the grid system and we will be going away for around 5 weeks. My security lights are connected to the solar system and that will be the only thing that will be on during this time. Together, they use around 40w. I have a Fivestar 3kv inverter with 2 panels and 2x 120kv batteries. Can I just leave it running, or is there a setting where I can lower the charging rate so it trickle charge the batteries for that time? I can only find "solar charge current ratio" in the settings menu. Not sure if this is the correct one. Thanks.
