March 16, 20233 yr I am using a Growatt 5000 es inverter installed 6 months ago in my display the solar line is interrupted every movement specially when the sun is brightly shining This is not happening during morning and afternoon inverter is working in all other aspects I want to know why the solar display line is interrupted ( Disconnected and connected)
March 16, 20233 yr What does your solar array consist of? i.e. how many panels do you have, how are they configured and what are the tech specs of these panels?
March 18, 20233 yr Author I have 6 panels 540w connected in series and I have been using same configuration for the last 7 months without issues I noticed this issue only few days ago
March 18, 20233 yr Author I only hear a beep sound when the PV power is disconnected but immediately it is get connected No error messages or error light is seen because of this issue I get very less solar output
March 18, 20233 yr Just a thought. There may be a break in solar feed at a certain temperature. If this is a predictable occurrence, then I would put a voltmeter on the solar input at the time and monitor the Voltage of the panels.
March 18, 20233 yr Author This is happening mostly when the sun is shining brightly When the sun light is low there is no interruption my inverter capacity is 5 kv but my Panal capacity is only 3.2 kv So can’t understand why the PV power is get disconnected and connected instantly
