March 23, 20233 yr Hi all I have a 5kva Growatt spf5000 inverter and 3kva Pylontech Lithium Battery. It stays on constant charge then eventually gives a 07 fault code due to the constant charge. If i switch number 5 setting to USE the battery goes into sleep mode randomly. Is anyone able to please help with the correct inverter settings?
