April 3, 20233 yr 2 x Growatt 5000TL 4x Pylontech 3000 24 x 335W panels Hi all, Just need advice here. I have the above setup and the setting for the Growatt + Pylontech in order to have the BMs working is LI (setting 5) and 2 or 4 on setting 36. The issue is that on setting 2 it only allows 16amps of charging current and on setting 4 74 amps. Is there any setting between this which allows the BMS to communicate correctly? I suppose question stems around the 25mm charging cable between the inverter and the batteries which get quite hot under setting 4 noted above. I assume the 25mm can take the 74amps but need some thoughts on this?? Thanks in advance.
